Displays the peer groups configured in the system.
| detail | Specifies to display the information in detailed format. |
| peer-group-name | Specifies a peer group. |
N/A.
If the detail keyword is specified then the parameters of the neighbors in the peer group, which are different from the ones that are configured in the peer group, are displayed.
If no peer group name is specified, all the peer group information is displayed.
This command applies to the current VR or VRF context.
The following command displays information for the outer peer group:
* (debug) Summit-PC.19 # show bgp peer-group "outer" Peer Group : outer Enabled : No AS : 65551 Router Enabled : Yes Weight : 1 ConnectRetry : 120 MinAsOrig : 15 HoldTimeCfg : 180 KeepaliveCfg : 60 Source Interface : Not configured RRClient : No Remove Private AS : No Router-Alert : Disabled Capabilities Config : ipv4-unicast ipv4-multicast route-refresh 4-Byte-AS Policy for NLRI Type ipv4-unicast In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : No Soft Input Recfg : Disabled Allow Looped AS-Path: No Policy for NLRI Type ipv4-multicast In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : No Soft Input Recfg : Disabled Allow Looped AS-Path: No Peers : 11.11.11.11 BGP Peer Group Statistics Total Peer Groups : 1 Enabled : 0 Disabled : 1
The following command displays information for the pg2 peer group with next-hop unchanged disabled:
Peer Group : pg2 Enabled : No AS : Not configured Router Enabled : Yes Weight : 1 ConnectRetry : 120 MinAsOrig : 15 HoldTimeCfg : 180 KeepaliveCfg : 60 Source Interface : Not configured RRClient : No Remove Private AS : No Capabilities Config : ipv4-unicast,ipv4-multicast,route-refresh (old & new) Policy for NLRI Type ipv4-unicast In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : No Soft Input Recfg : Disabled Allow Looped AS-Path: No NextHopUnchanged : Disabled Policy for NLRI Type ipv4-multicast In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : No Soft Input Recfg : Disabled Allow Looped AS-Path: No NextHopUnchanged : Disabled Policy for NLRI Type vpnv4 In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : Standard, Extended Soft Input Recfg : Disabled Allow Looped AS-Path: No NextHopUnchanged : Disabled Policy for NLRI Type ipv6-unicast In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : No Soft Input Recfg : Disabled Allow Looped AS-Path: No NextHopUnchanged : Disabled Policy for NLRI Type ipv6-multicast In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : No Soft Input Recfg : Disabled Allow Looped AS-Path: No NextHopUnchanged : Disabled Policy for NLRI Type ipv4-vxlan In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : No Soft Input Recfg : Disabled Allow Looped AS-Path: No NextHopUnchanged : Disabled Policy for NLRI Type l2vpn-evpn In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : Standard, Extended Soft Input Recfg : Disabled Allow Looped AS-Path: No NextHopUnchanged : Disabled Peers : 192.168.48.30
The following command displays information for the pg2 peer group with next-hop unchanged enabled:
Peer Group : pg2 Enabled : No AS : Not configured Router Enabled : Yes Weight : 1 ConnectRetry : 120 MinAsOrig : 15 HoldTimeCfg : 180 KeepaliveCfg : 60 Source Interface : Not configured RRClient : No Remove Private AS : No Capabilities Config : ipv4-unicast,ipv4-multicast,route-refresh (old & new) Policy for NLRI Type ipv4-unicast In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : No Soft Input Recfg : Disabled Allow Looped AS-Path: No NextHopUnchanged : Disabled Policy for NLRI Type ipv4-multicast In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : No Soft Input Recfg : Disabled Allow Looped AS-Path: No NextHopUnchanged : Disabled Policy for NLRI Type vpnv4 In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : Standard, Extended Soft Input Recfg : Disabled Allow Looped AS-Path: No NextHopUnchanged : Disabled Policy for NLRI Type ipv6-unicast In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : No Soft Input Recfg : Disabled Allow Looped AS-Path: No NextHopUnchanged : Disabled Policy for NLRI Type ipv6-multicast In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : No Soft Input Recfg : Disabled Allow Looped AS-Path: No NextHopUnchanged : Disabled Policy for NLRI Type ipv4-vxlan In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : No Soft Input Recfg : Disabled Allow Looped AS-Path: No NextHopUnchanged : Disabled Policy for NLRI Type l2vpn-evpn In Policy : None Out Policy : None NextHopSelf : Disabled Send Communities : Standard, Extended Soft Input Recfg : Disabled Allow Looped AS-Path: No NextHopUnchanged : Enabled Peers : 192.168.48.30
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
